Jimny auto advice needed
- Valleys rambler
18 Feb 2018 14:37 - 18 Feb 2018 16:58 #189433
by Valleys rambler
Replied by Valleys rambler on topic Jimny auto advice needed
Great stuff people, so is that the only parts I need, and can I leave all the rest on apart from the hubs because I wouldn't know where to start lol so basically be like my old vitara when I had to reverse back ???????
Last edit: 18 Feb 2018 16:58 by Lambert. Reason: No need for swearing.
18 Feb 2018 15:09 #189435
Replied by jackonlyjack on topic Jimny auto advice needed
Yes just remove old hubs and bolt new on it's that easy
You can leave every thing as was
OR remove the old rotten steel pipe work and just blank off the rubber pipes that's left on
The following user(s) said Thank You: Valleys rambler
18 Feb 2018 18:43 #189442
Replied by Riccy on topic Jimny auto advice needed
You dont need to reverse back to disengage the front drive. Use the transer box lever/dash buttons to put it in 2wd on and off tarmac. (important NOT to drive on grippy surfaces in 4x4!)
The manual (or freewheeling) hubs allow you to 'switch off' a wheel at a time. If your going onto slippery surfaces, switch them both on before and engage 4x4 as needed. once back to tarmac switch them off for better fuel consumption (stops the wheels turning the shafts needlessly).
The pipes and suchlike can stay, but do blank off any if you remove them. You may get problems with dash lights if theres a leak on it somewhere, so probably best to blank off fully as Jack says
- Valleys rambler
18 Feb 2018 20:16 - 18 Feb 2018 20:18 #189449
by Valleys rambler
Great stuff im daft when it comes to this stuff so yeah thats good news ill order a set can I just fit these and drive and not touch anything at all, and by blanking of where by and how, buy the way theres a fat reefer in the ashtray for you haaaa I need as much info as poss like any special tools could I do them myself etc:blink:
Last edit: 18 Feb 2018 20:18 by Valleys rambler.
18 Feb 2018 20:18 #189450
by kirkynut
Replied by kirkynut on topic Jimny auto advice needed
I know what you mean by reversing back to release any wind up in the transmission and Yes, you may need to do so for the 4wd to release and the light go out as the hubs will be locked while your old auto hubs wouldn't be.
- Valleys rambler
20 Mar 2018 16:07 #190630
by Valleys rambler
So I bought the hubs of Jimny bits also advised I don't need spacers etc, anyone got a tutorial video link on how to change them, so exited Haaaaaa
