02 Jimny oe driving lamps front
- CharlesS
25 Jan 2018 04:16 - 25 Jan 2018 04:17 #188828
by CharlesS
Replied by CharlesS on topic 02 Jimny oe driving lamps front
The Suzuki FSM does not label the way I expected. I could not locate in the FSM where the fuse box is located other than it is called the Individual Fuse Box 1 which has the headlight relays, condenser fan relay and fuel injection relay. The front fog lamp relay is in position 101 on the far end of the fuse box and appears to be a 15A rated relay.
Sorry I could not be of more assistance.
Last edit: 25 Jan 2018 04:17 by CharlesS.
- GRAYWOLF
29 Aug 2018 12:42 #195523
by GRAYWOLF
Replied by GRAYWOLF on topic 02 Jimny oe driving lamps front
Hi all, still not found this blasted relay, both lamps are fine, switch is fine, but i cant find it..when i switch lamps on, i caan hear a buzz..from lower right side nr.fuse box in cab, however i have swapped out all relays ther..still no luck, anybody out there got an 05..or 54 plate ragtop 02..with fitted oe fog/spots..that could give me a clue.??
- TaterTot
29 Aug 2018 13:40 #195528
by TaterTot
Replied by TaterTot on topic 02 Jimny oe driving lamps front
When they "Buzz", have you tried touching them? Buzzing relays often vibrate a bit.
- GRAYWOLF
29 Aug 2018 16:35 #195538
by GRAYWOLF
yep, and nope..rang Suzuki todaay, apparently, all spanish buil tor(dago built) as he put it, came into uk without spots/drivi8ng lamps..etc..
The o2 jimny both hard top, and convertible..had 2 x tone paint, o2 badges, and other stuff fitted in uk..as each one was sold..there is no hard and fast rule, as to where the relays etc..would be..hence nothing shows on ANY wiring loom, as i queried this! I have checke wiring back from lamps as far as i can, and, as yet havent been able to remove switch from faascia, as it seems to be tight with loom..all relays under dash, i have removed in sequence..and i still get the brrr..from low down inside, if i switch off, and on again, nothing..20mins later..i retry and same noise, so... if i can get the switch out without damage, i'try chasing back from there, i am a sparky by the way, i like a challenge, but this is doing my head in..so simple really, but such a pain to get sorted..cheers.
- TaterTot
29 Aug 2018 17:45 #195541
by TaterTot
Have you managed to identify which wire goes from the switch, and to the hidden relay? It would be way easier if you managed to get the switch out for sure.
29 Aug 2018 22:11 #195548
Have you tried using a stethoscope to locate the relay?
Replied by helijohn on topic 02 Jimny oe driving lamps front
Are you a car electrics sparky? I love dealing with car electrics (except modern cars which to my mind are getting out of control electricwise) but accept it can be truly infuriating especially as there seems to be no consistency across the manufacturers.GRAYWOLF wrote: i am a sparky by the way, i like a challenge, but this is doing my head in..so simple really, but such a pain to get sorted..cheers.
Time to create page: 0.560 seconds
