Tow bar & recovery options
18 Dec 2017 20:28 #187609 by Lambert
Replied by Lambert on topic Tow bar & recovery options
I have one of those for the Jeep and whilst it is perfectly secure it has over the years developed a very slight amount of play in the pin. With an empty trailer on it sounds like the back of the car is falling apart, such a distressing noise. I am keeping an eye out for the type where the ball is cast into the top jaw.
19 Dec 2017 06:47 #187613 by facade
Replied by facade on topic Tow bar & recovery options
"over the years......" B)
You don't get to use phrases like "over the years" with the stuff we get sold today. :angry:
Mine must be 25 years old (and on its 3rd or 4th towbar)- the zinc has long corroded off and it is black hammerite, but it doesn't get a lot of towing use.
  • Venter
19 Dec 2017 08:16 - 19 Dec 2017 08:16 #187614 by Venter
Replied by Venter on topic Tow bar & recovery options
facade wrote:
kirkynut wrote: Look at Dixon Gate tow hitches. Perfect for towing and recovery!
dixon-bate.co.uk/products/gb/130-bradley-jaws
Obviously cheaper from other sources.
I have the one called JAW-E40TC-3500K, the ball is on top of the pin, so I keep the ball & pin part out, and then you can read my numberplate. It is a towsure bar
the 5 tonne ones have 4 bolts
It's those two bolts which most usually fail
Last edit: 19 Dec 2017 08:16 by Venter.
19 Dec 2017 12:44 #187616 by Lambert
Aye and if you are being energetic enough trying to unstick a Jimny and manage to kill 2 m16 grade 8.8 bolts, I would suggest you are doing it wrong.
19 Dec 2017 15:18 #187619 by Busta
Replied by Busta on topic Tow bar & recovery options
11/60 wrote: Aye and if you are being energetic enough trying to unstick a Jimny and manage to kill 2 m16 grade 8.8 bolts, I would suggest you are doing it wrong.
Exactly this. If you apply the equivalent of 148,800 lbs of pulling force to the back of a Jimny those bolts won't be the only things to break!
I suspect most of the towball failures occur in America and Australia where they don't tend to use the same forged towball design as we do here and have much bigger, heavier trucks. In Oz, where a typical expedition Landcruiser or Patrol weighs about 4 tons, the towball is typically just bolted through a steel tongue like this:
There is also this kind of combination hitch which bend like a banana if you use them with the pin removed:
Apples and Oranges.
  • Venter
19 Dec 2017 19:49 #187635 by Venter
Indeed
