Flashing 4WD Light when disengaging
11 Dec 2017 05:07 #187310 by Lambert
They can sometimes be a bit clunky coming out of 4x4. If the light flashes after selection of 2wd, backing up a short distance is often enough to then allow it to disengage cleanly. From what you've described I don't think it has a fault as such.
11 Dec 2017 12:45 #187330 by Busta
I suspect you've put a fair amount of stress into the system driving that far on road in 4x4. Unless you are driving on a continuous carpet of snow you should be in 2wd and only select 4wd for the really slippery bits.
Time to create page: 0.200 seconds
