Max nose weight
- Ruedeleglise
17 Oct 2017 15:46 #185326
by Ruedeleglise
Max nose weight was created by Ruedeleglise
Hi, I am new here. I am very probably buying a jimny 4x4 for mixed work on and off road. I have tried to find the max nose weight for the car but only found once in some message......75 kilo? Advice please
- Thank you received: 1856
17 Oct 2017 16:05 - 17 Oct 2017 16:10 #185328
Replied by Lambert on topic Max nose weight
The owner manual states 10 pc of the gross trailer weight as towed which would be a maximum of 130kg but that would be quite a lot. 75kg would be a good idea.
Last edit: 17 Oct 2017 16:10 by Lambert.
The following user(s) said Thank You: Ruedeleglise
- Ruedeleglise
17 Oct 2017 16:17 #185330
by Ruedeleglise
Replied by Ruedeleglise on topic Max nose weight
Thanks. I have also a Duster and the spec states that if a 4x4 the max nose wt on the rear is greater than with the 2x4. This being due to the greater weight of the engine etc up front. I assumed that the max nose wt would be advised so that the front wheels are not too unweighted.
- 1066Boy
17 Oct 2017 16:45 #185331
by 1066Boy
Replied by 1066Boy on topic Max nose weight
For most vehicles 50 Kg is a good target for good handling.
22 Oct 2017 18:06 - 22 Oct 2017 18:07 #185426
by Foxtrot
Replied by Foxtrot on topic Max nose weight
Last edit: 22 Oct 2017 18:07 by Foxtrot.
22 Oct 2017 18:22 #185429
by Foxtrot
We must have the same taste in cars...I used to have a 4x4 Diesel Duster. The reason you can have more nose weight with the 4x4 is because it is recommended to tow I'm 4x4 mode and there will be traction with the back wheels as well as the front. In 2 wheel drive it is front wheel drive only and if the tow ball is too heavy it will make the front too light making the car lose traction.
Ruedeleglise wrote: Thanks. I have also a Duster and the spec states that if a 4x4 the max nose wt on the rear is greater than with the 2x4. This being due to the greater weight of the engine etc up front. I assumed that the max nose wt would be advised so that the front wheels are not too unweighted.
