Over sensitive
11 Oct 2017 16:19 #185099
Over sensitive was created by helijohn
Had an MoT done today and watched as he was poking with a long rod (to my mind a bit to eagerly) at the bodywork just on the forward edge of the rear wheel arches, So it failed on rust and I can't remember if they are allowed to poke with a tool.
The pic doesn't show it well.
It is not a big hole and may be about a foot from a seat belt mount. The other side is not nearly such a big hole
11 Oct 2017 17:09 #185100
Replied by mlines on topic Re:Over sensitive
Is it near a body mount?
Sent from my Nexus 6P using Tapatalk
- shakennstirred
11 Oct 2017 17:47 #185101
by shakennstirred
Replied by shakennstirred on topic Over sensitive
Cant see anything in the pic lol
- MadsV
11 Oct 2017 18:38 #185103
by MadsV
Replied by MadsV on topic Re:Over sensitive
If thats a fault in the uk, they are very strict. The easy way is to cut it clean, glue in a peace of steel and put some underbody sealant or something other rust preventive on. Its not dangerous rust so i dont understand why they put a fault on it
- Thank you received: 1876
11 Oct 2017 19:26 #185109
Replied by Lambert on topic Re:Over sensitive
Anything that constitutes a perforation of the body within 30 cm of a body mounting even if it is essentially a separate structure is classed as grounds for refusal.
11 Oct 2017 19:30 - 11 Oct 2017 19:36 #185110
by Busta
Replied by Busta on topic Over sensitive
Are you saying it wasn't rusty or wasn't within 30cm of a body or seatbelt mount? You can't poke a rod through steel that isn't rusty, and although I can't tell exactly from the picture it looks like it's close to the body and seatbelt mounts.
Just re-read your post. Yes they are allowed to poke with a tool. Otherwise people would just underseal over everything and they'd never know.
Last edit: 11 Oct 2017 19:36 by Busta.
Time to create page: 1.318 seconds
