RPM drop on electric load
- ggregorsch
06 Oct 2017 09:39 #184899
by ggregorsch
So maybe the brake booster is the cause?
How do I check it?
Sent from my Redmi Note 4 using Tapatalk
Replied by ggregorsch on topic Re:RE: RPM drop on electric load
I agree that it should be a small fluctuation but at 300-400 rpm the engine shakes and it creates the feeling it will stop in a second. It doesn't stop, but I doubt this happened when the car was brand new.Busta wrote: The brakes use the engine's vacuum so pressing then will normally cause the idle to fluctuate.
How do I check it?
- ggregorsch
03 Apr 2018 14:04 #191228
by ggregorsch
Problem solved, new wire between generator and 80A fuse in the engine fuse box.
For details, everyone is welcomed.
Cheers!
Cheers!
- Stumpjumper
03 Apr 2018 14:29 #191229
by Stumpjumper
Replied by Stumpjumper on topic Re:RE: RPM drop on electric load
Break in the wire or bad connection?
- X88RED
04 Apr 2018 16:05 - 04 Apr 2018 16:05 #191288
by X88RED
Replied by X88RED on topic Re:RE: RPM drop on electric load
Can you send me some more details on what you did or upload some pictures pretty please? I think I may have the same issue as you!
Last edit: 04 Apr 2018 16:05 by X88RED.
- Topherski99
25 Nov 2022 04:51 #246098
by Topherski99
Replied by Topherski99 on topic RPM drop on electric load
Hello same problem. Plss help mo
E
E
Time to create page: 0.252 seconds
