Kap landmaster
08 Oct 2017 07:08 #184968 by Riccy
I looked into it,
to do it properly would be best done with a bogie for the rear wheels and drive would need to use something like a second transfer box to split the rear output.
Never found out how well a jimny tbox would run in reverse? OK at lower speeds but what would happen at higher speeds? It would probably need to be a elec t-box with 1-1 in high range (low wouldnt be needed as the primary t-box would do that).
08 Oct 2017 10:37 #184973 by yakuza
Riccy wrote: It would probably need to be a elec t-box with 1-1 in high range (low wouldnt be needed as the primary t-box would do that).
Also Vitara has a 1:1 transfer but that box is not divorced like the jimny box. it is a bit shorter though.
08 Oct 2017 10:43 #184974 by yakuza
Also possible to weld up a second flange on the axle housing to put another diff facing rear on the fwd rear axle to drive aft rear axle..
Time to create page: 0.166 seconds
