2 Inch lift vs 3 Inch lift.
  • ViktorEInar
03 Oct 2017 00:06 #184766 by ViktorEInar
2 Inch lift vs 3 Inch lift. was created by ViktorEInar
Hey.
Jimny 2004 automatic.
Im thinking about going for 2 inch lift or 3 inch lift. Im going to use for snow and offroad here in Iceland.
I want to have my Jimmy on 31" tyres, but there is a twist, this is my only car so I will be using for town more than offroad.
What are your thoughts?
p.s. what and where is the best to get the kit from.
03 Oct 2017 00:40 #184767 by zukebob
Replied by zukebob on topic 2 Inch lift vs 3 Inch lift.
Regardless of 2" or 3" lift, with that tire size, you will likely have a problem if you achieve a near full compression of your suspension and haven't made some additional modifications. Unless you don't envision yourself driving terrain that could cause full suspension compression, you will probably need to do some fender trimming, a body lift or some other mod to keep the body away from the tires. You will also want to consider gearing changes with 31 inch tires.
  • Wokka
03 Oct 2017 05:32 #184769 by Wokka
Replied by Wokka on topic 2 Inch lift vs 3 Inch lift.
+1
The little 4 banger will have a tough time turning 31's with stock gearing.
  • 1066Boy
03 Oct 2017 07:37 #184773 by 1066Boy
Replied by 1066Boy on topic 2 Inch lift vs 3 Inch lift.
I think 28" tyres are around the limit without changing a whole load of other bits. :(
Time to create page: 0.153 seconds
