10 Tonne Press
- Thank you received: 115
18 Sep 2017 14:53 #184217
by maverick
Jalapeño, IISY?
10 Tonne Press was created by maverick
I'm thinking about buying one for myself at home ...
Has anyone got one at home and would they recommend it, and where did you buy it from?
Thanks
Brett
Thanks
Brett
Jalapeño, IISY?
- Thank you received: 683
18 Sep 2017 15:28 #184219
Replied by jackonlyjack on topic 10 Tonne Press
I don't own one but used this many times
www.machinemart.co.uk/p/clarke-csa10ep-1...nomy-hydraulic-floo/
Jack
Jack
18 Sep 2017 15:41 - 18 Sep 2017 15:43 #184221
by maverick
Jalapeño, IISY?
Replied by maverick on topic 10 Tonne Press
Thanks Jason - Is it good for the Jimny Long Rear Shafts too?
Jalapeño, IISY?
Last edit: 18 Sep 2017 15:43 by maverick.
18 Sep 2017 17:20 #184224
Never tried a rear shaft
But you could always remove the bed and use something on the floor
That will give you over 800mm
just make sure its bolted to the floor well
(i have no clue how much pressure you need to fit the bearing/retainer/abs ring)
or get a slimline bed fabricated
18 Sep 2017 17:50 #184226
Replied by Riccy on topic 10 Tonne Press
There are loads of copycat ones of the machine mart one linked on ebay. I would avoid it as the design allows for it to push off centre, risking the piece flying out of the machine under heavy pressure! Its essentially a sprungloaded bottle jack design. The ones which have a solid long ram are much safer.
This is the one i have (but it defo wont do the rear bearings as not long enough, does everything else happily and safely)...
www.machinemart.co.uk/p/clarke-csa10bb-10-tonne-bench-press/
Riccy
Riccy
- Thank you received: 923
18 Sep 2017 18:10 #184228
Replied by X8GGY on topic 10 Tonne Press
I've just switched between eBay accounts, and when I logged out it knew I'd just been on the MachineMart site looking at this, and it popped up and said use "EBAY20" at the checkout to get 20% off !
