2019 Jimny Sighting
01 Oct 2017 18:55 #184712
by furo
Replied by furo on topic 2019 Jimny Sighting
It looks promising to me! Maybe a bit wider than the current Jimny but otherwise very similar, so hopefully equally good off road. Also seems like it will be easily modified.
01 Oct 2017 19:53 - 01 Oct 2017 19:53 #184713
by Foxtrot
It looks great to me as well, I am glad they haven't followed the crowd with the soft off road option which can just about jump a kerb. One big improvement they could make is to use the AllGrip system in normal mode with a low 4x4 transfer box. I always found it was my Jimnys achilles heal that it was rear wheel drive when not in 4x4. It made winter driving hit and miss when to use the 4x4 system when on tarmac.
Replied by Foxtrot on topic 2019 Jimny Sighting
furo wrote: It looks promising to me! Maybe a bit wider than the current Jimny but otherwise very similar, so hopefully equally good off road. Also seems like it will be easily modified.
Last edit: 01 Oct 2017 19:53 by Foxtrot.
01 Oct 2017 20:45 #184717
Replied by helijohn on topic 2019 Jimny Sighting
Foxtrot wrote:
I must admit I have come to like permanent 4x4 systems or at the very least a selectable that can be left in four wheel drive.furo wrote: One big improvement they could make is to use the AllGrip system in normal mode
- 1anpoterrier
01 Oct 2017 21:33 #184719
by 1anpoterrier
Replied by 1anpoterrier on topic 2019 Jimny Sighting
As long as it is more reliable than it was in our vitara,15000 miles,wouldn't go in and out of low range unless it felt like it,traction control turning on and off its self which being linked to abs did the same with that,was not impressed,jimny at a year old and 5500 miles is not looking to promising either,build quality is going down hill and if new jimny is going to be made in India don't have a lot of faith in it
- Thank you received: 227
01 Oct 2017 23:35 #184720
by zukebob
Replied by zukebob on topic 2019 Jimny Sighting
The assumption seems to be that this new model will be unveiled at the Tokyo auto show at the end of this month (Oct 27 - Nov 5). Hopefully most of our speculation will end and they will provide some of the real specifications.
The following user(s) said Thank You: Foxtrot
- Thank you received: 1960
02 Oct 2017 17:37 #184747
Replied by Lambert on topic 2019 Jimny Sighting
As one of our main correspondent in the general vicinity will you be attending Tokyo on our behalf to get us some first hand intelligence on the new Jimny? (Yes I am joking and I am aware that Manila and Tokyo are not exactly near each other)
Time to create page: 0.551 seconds
