2" body lift
06 Feb 2011 16:58 #11101 by ooky_123
Replied by ooky_123 on topic Re: 2" body lift
Personally, I just did my usual and just jacked away ... :)
no, seriously, I disconnected the vacuum pipes (the rubber ones that you have highlighted, and reconnected them (although I donot use the Vac system any more).
The bits attached to the bulkhead I forgot about and when I jacked the body up, it just pulled loose of the bulkhead.
as for the distance required, a 2" lift will go on really easily, and you can get about 5" of height between the body and chassis so there is plenty of room to get the spacer blocks in.
The brake lines, will need to be modified (I fitted longer ones) .. or you can bodge (cutting slots into the body and dropping the mounting to account for the extra height (its a nasty fix and not recommended)
Former owner of Little "Ooky", who has now started a new life in Shetland
  • Strek
06 Feb 2011 17:12 #11105 by Strek
Replied by Strek on topic Re: 2" body lift
Hmm. Are the ones whith my arrows in the pictures vacuum pipes? I was sure they are brakepipes? The ones along the crossmember, are they vacuum?
06 Feb 2011 17:20 #11109 by dirtydogz
Replied by dirtydogz on topic Re: 2" body lift
The ones with the black sleeves are brakepipes.
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
  • Strek
06 Feb 2011 17:28 - 06 Feb 2011 17:28 #11111 by Strek
Black sleeves?
Is this correct?:
Brakelines:
Vacuumlines:
Last edit: 06 Feb 2011 17:28 by Strek.
06 Feb 2011 17:29 - 06 Feb 2011 17:42 #11112 by dirtydogz
Attachment BLOG1160_2011-02-06.JPG not found
YES)
If you look below that you will find a brake union as in photo 3 if you undo the bolt holding it you can push it up when you lift the body, and make a bracket as in my photo.
hope this helps.
Last edit: 06 Feb 2011 17:42 by dirtydogz.
06 Feb 2011 18:30 #11115 by ooky_123
My bad .... I only glanced at the pictures on my iPhone.
I didn't touch the brake pipes at all
Time to create page: 0.168 seconds
