Biggest tyres I can fit with a 3inch lift without any cutting????
- ConnorH
20 Jun 2017 12:35 #182226
by ConnorH
Biggest tyres I can fit with a 3inch lift without any cutting???? was created by ConnorH
I've been trying to find a definite answer to the question on what biggest tyres I can fit with a 3inch lift? I was hoping I could fit 235/75/15s on standard jimny wheels but I keep seeing a few people saying 215/80/15s so can someone give me a definite answer please. I want to take it off road so I'll be getting mud terrain tyres
Cheers guys
Cheers guys
- ilten
20 Jun 2017 15:39 #182229
by ilten
Replied by ilten on topic Re:Biggest tyres I can fit with a 3inch lift without any cutting????
There are no definite answers to these questions. Which tires exactly? How much backspacing? Which wheels? Which radius arms? Are you limiting uptravel with longer bumpstops or spacers? Why on earth don't you cut your fenders? Do you have the gearing to turn the bigger tires?
Gesendet von meinem SM-T310 mit Tapatalk
- 1066Boy
20 Jun 2017 16:13 #182230
by 1066Boy
Replied by 1066Boy on topic Re:Biggest tyres I can fit with a 3inch lift without any cutting????
235/75/15 are almost 3" bigger than stock and that's without adding the extra width into the mix.
215/80/15 will work but will be close without any trimming especially with a Mud pattern.
I have 215/75/15 and a 2" lift and its fine even on full flex but the tyres are not over aggressive.
As stated before depends on the tyre as they vary a lot in there true high/width.
20 Jun 2017 17:47 #182232
by Busta
Replied by Busta on topic Biggest tyres I can fit with a 3inch lift without any cutting????
You won't get away with 235/75 r15 without any trimming unless you severely restrict the suspension travel. They are simply too big to go up into the arches. The biggest will be 215/75r15 which, incidentally, is also the biggest you can fit with no lift at all.
- Thank you received: 923
20 Jun 2017 18:05 - 20 Jun 2017 19:06 #182233
Replied by X8GGY on topic Biggest tyres I can fit with a 3inch lift without any cutting????
I've got BFG AT 235/75/15s on mine, with a 2" (trailmaster) suspension lift and a 2" body lift -
Edit : Although if I'd used remoulds they probably wouldn't have fitted as they are usually bigger than the stated size
But it's just a daily driver... as Busta says I think the tyres would touch if I took it offroad and twisted the axles up... But on road, they are fine.
I've had to alter the gearing to compensate for the larger diameter / circumference of the tyres though... Edit : this would be my biggest worry of going 'so' big...
I've got 31"s on the offroad toy though! -
With plenty of arch cutting!
As the others have indicated it depends what you want to do with the Jimny?
Last edit: 20 Jun 2017 19:06 by X8GGY.
21 Jun 2017 09:53 - 21 Jun 2017 10:02 #182237
Replied by yakuza on topic Biggest tyres I can fit with a 3inch lift without any cutting????
Loose the mud flaps and you can fit 235/75-15 with 2-3" lift.
Normal road use with not too many passengers or heavy loads it will be fine.
slight rub on full flex and/or very heavy load.
I run 235/75-15 on original alloy wheels, two inch lift. On normal day to day use it is ok (for me).
I think it is not so much the lift, but also the correct wheel offset and brand of tire. cause it is very close on my car..
others will probably not be ok with this i see, but i will accept some slight rub offroading.
And totally agree with S200KYS worry for the gearing.
I find that 1600 motor corrects this as i like to drive on low rpm and M16 has good low end torque.
But for jimny with M13/G13 engine 235 tires really steal your motors "power".
Driving with 235 and 1300 can not pull the skin of the sausage (norwegian/local saying)
Last edit: 21 Jun 2017 10:02 by yakuza.
Time to create page: 0.169 seconds
