jimny on disco 1 running gear
- Dlmcs
09 Apr 2017 16:58 #180091
by Dlmcs
jimny on disco 1 running gear was created by Dlmcs
Hi i have a 2001 jlx jimny in my garage which I havent realy decided what to do with it i bought 16 x 7 wheels and 235 x 16 x 80 tyres but i still dont like it im thinking of buying a disco 1 complete and replacing axles transfer box gearbox and tdi unit does anyone have any expearance with this and any real info will be most welcome I am a skilled mechanic when I left school and now have been in heavy engineering for last 20 years with great deal of electronical expeirance but am slightley disabled but have all the kit i need to do the job i want to go offroading with my welsh friends they go through the welsh forests slowley so that is my aim also will be selling parts that I will be exchanging ther engine is good axles have been rebuilt eith new bearings and seals and pads
- OllieNZ
09 Apr 2017 17:32 #180092
by OllieNZ
Replied by OllieNZ on topic Re:jimny on disco 1 running gear
The axles would be worth a shot if you want to run bigger tyres and gain some width but every thing else would be too heavy. I'd look into lighter running gear. There are very few light weight diesels out there (compared to a stock jimny engine) and even fewer have attempted to fit them to a jimny (1.7 Isuzu being most common). From what I've read on those that have fitted xud or pd engines to samurais it's definitely affected the handling some have considered it worth the trade off others not so much. A manual jimny engine and gearbox weighs in around 120kg dripping wet. An xud or pd engine weighs considerably more on its own. I've not no idea what a 200/300tdi weighs
- Dlmcs
09 Apr 2017 17:47 #180093
by Dlmcs
Replied by Dlmcs on topic Re:jimny on disco 1 running gear
Hi thank you for your response the reason that I want to use the ruuning gear is that it will take the weight of the engine / gearbox and Im thinking that transfer box wouuld be a good move to use the landy one as the susuki one is vey light duty. do you still not think using the whole lot that it would affect the haddeling I was thinking that stuffing all that heavy duty kit would make an awsome go any were kind of all terrain viehicle im thinking of useing springs steering rack shortend propshafts and so on your views are very important to me at this designing stage
- OllieNZ
09 Apr 2017 18:04 #180095
by OllieNZ
Part of what makes the jimny is its light weight, I can understand the axle swap but I'm struggling with why the landrover engine/gearbox? There are much lighter and just as powerful if not more so engine gearbox combo's out there. As for the transfer case, swap the jimny one for an sj410 one or splurge (well worth the money imo) on a rock lobster (remanufactured sj410/sj413 hybrid transfer case)
- Thank you received: 1884
10 Apr 2017 04:24 #180099
Replied by Lambert on topic Re:jimny on disco 1 running gear
Making a Jimny into a land rover is pointless. It will be just as wide as a land rover, 90pc as heavy as a land rover, have the turning circle of a land rover, be even less reliable than a land rover and be a massive amount of time and money to make. If that's what you want then I would look forward to the build thread as a technical exercise but as a practical off road car i would encourage you to put some mud tyres on the stock Jimny, go to the nearest off road centre and get some focused tuition from someone who understands the attributes of a Jimny and learn how to drive past land rovers, because a Jimny in the right hands is an epic weapon for upsetting land rover fan boys.
10 Apr 2017 08:02 #180102
by Busta
Replied by Busta on topic jimny on disco 1 running gear
I agree with 11/60. It's a great engineering exercise but a lot of work to make something that won't be very special. It will basically be a Defender with a Jimny body. Heavy, slow, wide, not very manoeuvrable...
I'm sure if you sort the gearing to match your tyres, buy stronger shafts and maybe fit a 1.6 you will find the Jimny on your current tyres is more than a match to any Landrover.
Time to create page: 3.034 seconds
