Why there is big diff look between 2 inches and 3 inches lift?
- Jimny987
28 Mar 2017 04:48 - 28 Mar 2017 05:06 #179725
by Jimny987
Why there is big diff look between 2 inches and 3 inches lift? was created by Jimny987
Hi Guys,
Why there is a big diff look between 2 inches and 3 inches?
Does any one know why?
Last edit: 28 Mar 2017 05:06 by Jimny987.
- Thank you received: 226
28 Mar 2017 06:35 - 28 Mar 2017 06:35 #179726
by zukebob
Replied by zukebob on topic Why there is big diff look between 2 inches and 3 inches lift?
It would primarily be 2 factors. Vehicle weight and a combination of a vendor's free height and spring rate of the springs.
In other words, installing the same manufacturer's 2 inch or 3 inch (approximate) lift springs on a fully loaded Jimny (steel bumpers, winch, underarmor, etc.) vs a stock Jimny, they won't sit the same. Add to that the technical data variations between manufacturers and you add even more variation into the equation.
Tom will be along soon
Last edit: 28 Mar 2017 06:35 by zukebob.
- TomDK
28 Mar 2017 07:08 - 28 Mar 2017 07:10 #179727
by TomDK
Replied by TomDK on topic Why there is big diff look between 2 inches and 3 inches lift?
I think you got it all covered
Last edit: 28 Mar 2017 07:10 by TomDK.
- Jimny987
28 Mar 2017 08:13 - 28 Mar 2017 08:21 #179730
by Jimny987
Replied by Jimny987 on topic Why there is big diff look between 2 inches and 3 inches lift?
Thanks for reply.
I understand the vehicle weight cause a diff look.
But in the same situation(Vehicle weight and vendor's free height), I saw the 3 inch lift is quiet bigger the 2 inch by measuring the length from tyre to fender trim.
What cause the difference? could it be springs only? or is my measurement wrong?
Last edit: 28 Mar 2017 08:21 by Jimny987.
- TomDK
28 Mar 2017 08:24 #179732
by TomDK
Okay. Here I go
Springs are made in different rates to match different type of vehicle weights. Like, a Diesel Jimny weighs around 100kgs more than an equal petrol Jimny. This means it will need stiffer springs. Especially on the front axle. Same goes when fitting a winch bumper and winch.
Diff? Differential? Different?
The only way of comparing two different springs is by knowing all details about them. Like free length, spring rate and such.
And this is why I recommend people only buy quality springs from known brands. they usually come with all these details listed.
- Jimny987
28 Mar 2017 08:59 - 28 Mar 2017 09:04 #179733
by Jimny987
Last edit: 28 Mar 2017 09:04 by Jimny987.
