Jimny Toe in questions.
  • Crumbley
29 Dec 2016 11:07 #176049 by Crumbley
Jimny Toe in questions. was created by Crumbley
I took my 2014 Jimny for tracking check.
They charged me £45 to adjust the toe in but the car didn't feel right driving down the road and I went back 3 times to ask them why it didn't feel right.
I tried to get them to tell me to prove that the £32,000 tracking machine had the correct settings.
Suzuki emailed be the toe in in mm and the wonderful machine only worked i degrees and minutes.
The guy thought that the inches shown as mm equivalents on the Suzuki specification was the tow in because the number had in (short for inches) after it.
They said that the £32,000 machine could not be wrong.
They could not tell me how to convert mm to degrees and minutes and in the end they refunded my money and questioned my mental health.
Took the Jimny to another tracker who used a mechanical tracking company.. I took them one minute to find the cause.
The first company had not checked the tyre pressures.
OK, question time.
If the toe in is say 4 mm is this the total distance between the front of the wheel rims is less than the distance between the rear of the wheel rims, at the height of the centre of the wheels?
In other words, are the measurements taken at the wheel rims at hub centre height?
29 Dec 2016 18:02 #176067 by facade
Replied by facade on topic Jimny Toe in questions.
In the manual it shows this:
However, it says toe-in was measured using a toe-in gauge, which measures between the rims at the centre of the wheel as you suppose.
I can see why the fancy optical measures the angle, it is easier than the actual distance, but you'd have thought that there would be a converter built in.
Mathematically, if each wheel is 15" diameter, and toed in 1-3mm (0.04-0.12") then the angle each wheel is toed in is found from arc-sin (0.04/15) to arc-sin (0.12/15) which is between 0.153 and 0.458 degrees. (9.2' to 27.5' )
Likely the machine measures each one separate for this 4 wheel alignment thingie, but it could double them up to give the total.
The following user(s) said Thank You: Crumbley
  • JimnyManREME
29 Dec 2016 20:22 - 29 Dec 2016 20:36 #176076 by JimnyManREME
Replied by JimnyManREME on topic Jimny Toe in questions.
The answer to your question is Yes. But before they can get accurate readings the garage should check the wheel bearings, steering track rod and track rod ends, and suspension components for wear, security and damage. The road wheels also need be checked for distortion, as well as tyre pressures.
Last edit: 29 Dec 2016 20:36 by JimnyManREME.
  • Crumbley
30 Dec 2016 12:35 #176097 by Crumbley
Replied by Crumbley on topic Jimny Toe in questions.
Absolutely great response, thank you.
I'd better bone up on my trig, last used 50 years ago.
Just found a conversion chart that can be lifted off the internet.
The link is www.trackace.co.uk/manual/conversion%20chart.pdf
  • Crumbley
30 Dec 2016 12:50 #176098 by Crumbley
Excellent response, thank you.
Just what I needed to understand toeing.
The company with the £32,00 tracking machine couldn't even tell me what the printout colours or numbers meant and they would not let me watch the mechanic working on my car.
Their printout showed 10 areas of adjustment but the Jimny only has 2. Still charged me full price which is about double the local tracking charge.
Something to be said about the piece of string and an adjustable measuring rod method for a Jimny..
30 Dec 2016 13:31 #176099 by facade
Crumbley wrote: Absolutely great response, thank you.
Hey look at that- 1mm = 9' 3mm = 27' B)
I had The Other Car on a 4 wheel alignment rig once, I'm sure they don't use them correctly, all the measurements I assume are relative to the longitudinal axis of the car, but they don't make any effort to set this, so I can't see how they could claim "one back wheel is to-ed in more than the other" when they have no zero reference.
Time to create page: 0.238 seconds
