help with pas tensioner bolt
  • just
24 Nov 2016 15:13 #174874 by just
help with pas tensioner bolt was created by just
hi i have searched the forums but couldnt find any info.
i have a problem at the moment i am trying to replace the alternator drive belt but need to remove the pas belt first on a 07 jimny vvt the problem i have is the tensioner adjustment bolt wont undo do you know what size it is supposed to be? and if anyone has any ideas as to how to undo it as its recessed into the tensioner and has little space around it?
thanks just
  • mickt
24 Nov 2016 19:05 #174878 by mickt
Replied by mickt on topic help with pas tensioner bolt
12mm I think
24 Nov 2016 19:44 #174880 by Busta
Replied by Busta on topic help with pas tensioner bolt
Yes, 12mm. Try an offset ring spanner or socket on a 1/4 inch ratchet or T-bar
24 Nov 2016 19:50 #174881 by Busta
You can gain a bit more space for access by removing the bolts at each side of the top of the radiator and tilting the radiator forward an inch or so.
  • just
25 Nov 2016 15:39 #174913 by just
Replied by just on topic help with pas tensioner bolt
thanks all i have done all tbese things prior to asking for help it appears that the bolt head was less than 12mm after the dealership fixed the blown crank pully and tighted it with a gorrilla. sso 12mm no longer fits even a 6 sided socket.
kind of stuffed at mo horse shoe nail, etc.
cheers just
  • Brebaz
25 Nov 2016 17:40 - 25 Nov 2016 17:43 #174919 by Brebaz
Replied by Brebaz on topic Re:help with pas tensioner bolt
Try an 11mm or a knackered bolt extractor
Last edit: 25 Nov 2016 17:43 by Brebaz.
Time to create page: 0.178 seconds
