Jimny bad road and dirt road handling
  • Caulkheader
10 Aug 2016 07:47 #171202 by Caulkheader
Replied by Caulkheader on topic Jimny bad road and dirt road handling
Yes I would check tyre pressures, tyre make / type and shocks BUT you have to remember it will never perform like a modern passenger car or crossover on the road. It's designed as a 4x4 utility vehicle and does that extremely well, it's less good on the comfort on road performance. Two different purposes and design needs.
  • Shep
13 Aug 2016 11:59 #171276 by Shep
Replied by Shep on topic Jimny bad road and dirt road handling
I use high range 4wd on dirt roads. Works much better.
  • JimnyMax
15 Aug 2016 02:43 #171321 by JimnyMax
Replied by JimnyMax on topic Jimny bad road and dirt road handling
Caulkheader wrote: Yes I would check tyre pressures, tyre make / type and shocks BUT you have to remember it will never perform like a modern passenger car or crossover on the road. It's designed as a 4x4 utility vehicle and does that extremely well, it's less good on the comfort on road performance. Two different purposes and design needs.
Spot on!
16 Aug 2016 21:20 - 16 Aug 2016 21:21 #171370 by mark98
As others have said, its the overall suspension setup which is responsible for the on road handling and comfort. They can be rough over bumps and jump around a bit, but when travelling alone I ignore it. I find they actually handle quite well when you consider the live axle setup :)
Last edit: 16 Aug 2016 21:21 by mark98.
  • helijohn
17 Aug 2016 21:02 #171408 by helijohn
Replied by helijohn on topic Jimny bad road and dirt road handling
mark98 wrote: As others have said, its the overall suspension setup which is responsible for the on road handling and comfort. They can be rough over bumps and jump around a bit, but when travelling alone I ignore it. I find they actually handle quite well when you consider the live axle setup :)
I go with this especially if you are used to a more conventional car then the Jimny is like a Drayton Manor Park ride for jolts and bumps.:laugh: :blink:
Time to create page: 0.269 seconds
