Radiator cap
22 Jul 2016 05:08 #170339 by Mike G
Radiator cap was created by Mike G
Ok,
Need some advice. I'm looking for a new radiator cap for my M13 Jimny engine, but can't tell whether I should fit a 0.9 or 1.1.
Can anyone clarify what pressure rating should be used on what engines? I don't have specific drawings to refer to and can't find anything to confirm it. Some eBay listings say a 0.9 is for 98 to 00, then others list the same vehicles in the compatible vehicle lists. I could email them, but I'd rather get advice from some clued up Jimny owners.
Cheers
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
22 Jul 2016 05:32 #170340 by Lambert
Replied by Lambert on topic Radiator cap
Mine is a vvt m13 and is a 1.1
  • 1066Boy
22 Jul 2016 06:50 #170343 by 1066Boy
Replied by 1066Boy on topic Radiator cap
0.9 Bar on mine. 2005 VVT. :)
All of the jap cars i have owned have had the 0.9 as standard.
If the is a option i would always go low. If the system is under too much
pressure its better to have the cap release it than blow a hose. ;)
22 Jul 2016 11:01 #170354 by Mike G
Replied by Mike G on topic Radiator cap
Thanks guys,
That's cleared things up nicely. :laugh:
Mine is 07 M13 VVT, so it looks like I might have to buy both of them.
22 Jul 2016 11:30 - 22 Jul 2016 11:33 #170356 by Mike G
No eBay APP ID and/or Cert ID defined in Kunena configuration£33.55 for a radiator cap on eBay!
Surely there must be a better deal on these. This is part of the reason I don't own a sports car.
Last edit: 22 Jul 2016 11:33 by Mike G. Reason: eBay link didn't work
22 Jul 2016 12:55 #170359 by Mike G
Ok,
So I dug out the manual for the M13 engine and there's a section on the radiator cap. It doesn't differentiate between VVT and non-VVT models, but it looks like it should be a 1.1 cap.
Also, interestingly, the overflow bottle cap has an orientation also. Not sure what the purpose of that is other than correct hose routing angle.
Time to create page: 0.246 seconds
