Tyre & Wheel Advice needed!
  • Venter
10 Jul 2016 16:03 #169826 by Venter
Replied by Venter on topic Tyre & Wheel Advice needed!
Looking at Koais' lifted Jimny, I'd have to change my mind on what I said in the earlier pm, probably not worth just giving it a go, as it's most likely require pretty extensive arch modification, so just stick with them on standard rims until you've saved up for a lift.
[IMG
[IMG
  • Daniel30
10 Jul 2016 16:32 - 10 Jul 2016 16:33 #169828 by Daniel30
Replied by Daniel30 on topic Tyre & Wheel Advice needed!
Extensive wheel arch modification for 215/75/15 ???????
:blink:
Last edit: 10 Jul 2016 16:33 by Daniel30.
  • Mr. F
10 Jul 2016 17:09 #169830 by Mr. F
Replied by Mr. F on topic Tyre & Wheel Advice needed!
That would be 215/75/15's on Negative Offset rims?
Just need to know if I could fit them to a standard un-modded Jimny.
Help! :)
Daniel30 wrote: Extensive wheel arch modification for 215/75/15 ???????
:blink:
  • Venter
10 Jul 2016 18:01 #169835 by Venter
Looking at the other pics above, there's a chance that some liberal use of the grinder may be required if mounted on ET-30 rims with no lift. They fit fine on my standard rims though.
  • 1066Boy
10 Jul 2016 19:55 #169855 by 1066Boy
Replied by 1066Boy on topic Tyre & Wheel Advice needed!
Too much off-set + larger size, doing this without a bit of cutting will be a problem. :)
[IMG
Time to create page: 0.593 seconds
