Lot of problems in my new car :(
- MrMarwanH
01 Jul 2016 20:55 #169411
by MrMarwanH
Replied by MrMarwanH on topic Lot of problems in my new car :(
- MrMarwanH
01 Jul 2016 20:56 #169412
by MrMarwanH
of course not
- MrMarwanH
01 Jul 2016 21:00 #169413
by MrMarwanH
Can you describe to me if the performance of your car is constant? I mean air-conditioning for example, the purrs you feel through the steering wheel..
- MrMarwanH
01 Jul 2016 21:29 #169415
by MrMarwanH
well item 5.) the steering wheel easy/hard to turn and item 3.) air con issue are most likely related as they're both on the same drive belt.
and 4.) shaking when stationary and 1.) shaking when driving are probably related - so maybe engine mounts or similar issues.
and a dodgy sensor or EGR valve can give performance issues as in 2.) someone here will be able to remember which one
but think you need to visit a garage/mechanic to sort things
Thank you 4 your response, I hope you can further help me.
I'll specify all my problems : when I first start the car the steering wheel is very easy to turn, but as soon as I move it became harder until the next time I start the car from off.
The problem of the steering wheel not turning completely while reverse happened to me 3 times ( my car just finished 4000 KM)its not a big deal but I'm afraid of the problem to be expanded.
Shaking while stationary in the steering wheel is small and the RPM is constant (I guess its normal for an old architecture engine), but shaking from underneath happen when I drive for so long and then had to stop at traffic light for example.
For the overall shaking of the car while driving maybe its because of bad storage of the car (its 2015 model, so it stayed on its tiers for more than a year) I met two guys bought it from the same dealer (both change their tiers, one got the problem fixed the other not) so I should give it a try
And I new problem , I smell gas when I wait in the car while on for like 10 minutes, from the air condition and out side the car, a very strong smell and goes after you move again, and I got an extreme headache from gas smell.
my car production date is : oct/2014 , is there any recalls for my car modle
I hope you all can help me, its my first new car and I'm very sad about is
also how good is my english, its not my first language
03 Jul 2016 16:43 #169477
by Rhinoman
Replied by Rhinoman on topic Lot of problems in my new car :(
I would start by checking the tension of the auxiliary drive belt. Is your vehicle OBD2? if it is then buy a cheap scan tool so you can the live data stream for indications of a fault with the engine management system.
Time to create page: 0.209 seconds
