Diff filler plugs
  • Barkis21
22 Jun 2016 15:46 #168994 by Barkis21
Diff filler plugs was created by Barkis21
Hi all went to change my diff oils today the drain ones can be undone no issues but both filler plugs are stuck tight can't budge at all is welding a nut/bolt the best option and where will I get new ones as they are out of stock on big Jimny?
22 Jun 2016 18:14 #169001 by X8GGY
Replied by X8GGY on topic Diff filler plugs
One of mine wouldn't come out the other day whilst fitting a 'new' rear axle... 30 seconds of heat from a blow torch and then grabbed it with a pair if mole-grips and it came straight out...
  • mickt
22 Jun 2016 20:03 #169014 by mickt
Replied by mickt on topic Diff filler plugs
Are you using a 10mm square drive as the 3/8 is too small?
  • Barkis21
22 Jun 2016 21:22 #169018 by Barkis21
Replied by Barkis21 on topic Diff filler plugs
Yeah 10mm bit won't budge bottom ones are loose but not the top
23 Jun 2016 05:42 #169029 by kirkynut
Replied by kirkynut on topic Diff filler plugs
Big Mole Grips round the outside and a tap with a hammer. That's the only way I found works but as Dave says, a bit of heat helps.
I've had nuts welded to mine to solve this problem now.
23 Jun 2016 07:36 #169036 by facade
Replied by facade on topic Diff filler plugs
There is a nylon washer underneath the flange as a seal, so be careful with the heat.
I tapped mine round with a chisel then did this:
(My stick welding is useless, but it has stayed together for years ;) )
Time to create page: 0.186 seconds
