Cv & half shaft spline count
- Unrealmcoy
05 Jun 2016 15:08 #168022
by Unrealmcoy
Cv & half shaft spline count was created by Unrealmcoy
Hello all,
Busy rebuilding the front axle and true to form its not straight forward.
After sourcing a pair of cv's I removed my old ones from the half shafts (had to cut them off, would not budge for love nor money) to discover my half shafts are 29 splines on the wheel end, 22 splines on the diff end.
The new cvs are unfortunately for a 19 spline half shaft
Does anybody know which Jimnys have which spline counts?
Ideally I would get a spare axle from the scrapers but there's no way of knowing how many splines on the halfshafts until the axle is payed for, home and stripped.
The alternative is a Suzuki dealer but at their prices I may as well get a set of long fields!
Any info is appreciated!
05 Jun 2016 17:16 - 06 Jun 2016 06:14 #168028
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Cv & half shaft spline count
If you get full shafts with cv's they will fit complete as a set. I only know of 19 and 20 spline cv's though never heard of 29? The 20 spline replacement cv's seem hard to get hold of/find.
Grey pick up Jimny
Last edit: 06 Jun 2016 06:14 by j999pre.
- Paterson
05 Jun 2016 22:09 #168043
by Paterson
Replied by Paterson on topic Cv & half shaft spline count
Had the same issue with mine ...I ended up buying a set of i
19t shafts as that size cv is much easier to get hold of and cheaper in the long run
06 Jun 2016 05:47 #168053
by safari
if u worry u die if u dont worry u still die so why worry
Replied by safari on topic Cv & half shaft spline count
as j999 told u as long u get a set of shaft and cv they all fit
- Unrealmcoy
06 Jun 2016 22:10 #168141
by Unrealmcoy
Replied by Unrealmcoy on topic Cv & half shaft spline count
Ended up going to the scrapers today and fetched the 19 spline shafts from an old nail, there's no other way when Suzuki want over £700 for a pair
Did you have any trouble getting the cvs off your old (29 spline) shafts?
The cv's on my new shafts tapped straight off but the cv's on my old 29 spline shafts drove the c clip into the splines splayin them out and ruining the shaft instead of compressing the clip.
Wondering if it's a design flaw with those 29 shafts or if I'm just unlucky?
Time to create page: 0.186 seconds
