spring length
- Terminator
02 Jun 2016 20:59 #167877
by Terminator
spring length was created by Terminator
We have just got a 2" lift kit suspension kit. Now 2 of the springs are of equal length and the other 2 have a 1" or so difference in length. Do the equal ones go on the front, and the unequal ones on the rear.Which of the slightly longer spring goes on what side.??
02 Jun 2016 21:18 #167882
Replied by mlines on topic Re:spring length
You need to ask the supplier. Some kits have different fronts, some have different rears and some have springs of the same length but with different rates.
Sent from my Nexus 6P using Tapatalk
- 1066Boy
03 Jun 2016 06:07 #167896
by 1066Boy
Replied by 1066Boy on topic spring length
normally shorter ones on rear, odd size longer ones on the front.
Longest one is drivers side, or it was with mine.
- Terminator
04 Jun 2016 17:14 #167974
by Terminator
Replied by Terminator on topic spring length
I have fitted 2 new springs on the front ,they were of unequal length and I have 2 springs to go on the back which are of equal length,they are the same length as the old fronts??the old front ones have a white and moave dot of paint. I'm a bit confused now,as to what spring goes where.
- Thank you received: 923
04 Jun 2016 21:09 #167998
Yes, that's right, I lifted my new red Jimny with 4 front springs... 2 on the back -
rear spring on the left, new (front) spring on the right...
new front spring for the front, with a spring spacer on the top...
Replied by X8GGY on topic spring length
Terminator wrote: I have fitted 2 new springs on the front ,they were of unequal length and I have 2 springs to go on the back which are of equal length,they are the same length as the old fronts??the old front ones have a white and moave dot of paint. I'm a bit confused now,as to what spring goes where.
The following user(s) said Thank You: Terminator
Time to create page: 0.198 seconds
