M16a VVT engine
28 Apr 2016 12:16 #165919
by Busta
Replied by Busta on topic M16a VVT engine
I got new inlet and exhaust gaskets and re-used everything else. There are a few gaskets for the water pump and other things that it might be worth changing.
Swapping the parts over from one engine to the other took longer than I expected but otherwise it was all fairly straight forward.
28 Apr 2016 13:37 #165921
by minibbb
Replied by minibbb on topic Re:M16a VVT engine
As busta says (he told me what to get
I got my gaskets from Suzuki as I wanted the right ones and decent quality. The oil filter screw was £8 from them IIRC
28 Apr 2016 13:46 #165922
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Re:M16a VVT engine
I have a Liana throttle body spare that you could swap the iac valve onto from the jimny. They are supposed to be sightly wider diameter.
Grey pick up Jimny
- Thank you received: 142
28 Apr 2016 14:14 #165924
by gilburton
Replied by gilburton on topic M16a VVT engine
I'll see how it goes with the standard parts as I was thinking of simplicity and ease of swap.
Once it's up and running I'll see if I need to unleash a few more horses :laugh:
Re gaskets I presume you bought M13a ones rather than the M16a ??
I've just been out looking at the Jimny a bit closer just to see what needs doing. Apart from all the plugs and various pipes/hoses it looks fairly straightforward.
It's years since I've done an engine swap though as these days it's much harder with emissions/laws and,of course, engines tend to last a lot longer but this swap seems one of the easier.
28 Apr 2016 18:55 - 28 Apr 2016 18:56 #165942
by Busta
Get normal Jimny gaskets, although I suspect the Swift ones are the same.
Yeah it's pretty straight forward. Access to some of the bolts down near the starter is the trickiest bit. I found supporting the chassis and letting the axle hang gave a bit more room to swing a ratchet.
Last edit: 28 Apr 2016 18:56 by Busta.
Time to create page: 0.139 seconds
