Jimny radio replacement
  • Mulberry
26 Jan 2016 23:12 #161270 by Mulberry
Jimny radio replacement was created by Mulberry
How easy is it to fit a replacement aftermarket radio/nav/cd player into my 2005/2006 Jimny
Is the wiring compatible with say a Seicane and can you remove the dash easily
My Radio has stopped working
27 Jan 2016 00:44 - 27 Jan 2016 07:46 #161273 by zukebob
Replied by zukebob on topic Jimny radio replacement
I purchased one of the Seicane units recently for my Jimny. Haven't installed it but found this in the How-to guides:
www.bigjimny.com/images/documents/dashcenterpanelremoval.pdf
It looks pretty straightforward.
As far as the Seicane goes, at the time of the order, they confirm what year and model it goes into so that they can supply the correct cables. I don't know if other suppliers do the same.
Bob
Last edit: 27 Jan 2016 07:46 by zukebob.
The following user(s) said Thank You: Mulberry
  • pellaaa
27 Jan 2016 07:36 #161279 by pellaaa
Replied by pellaaa on topic Jimny radio replacement
yes if you follow the guide above is pretty easy..i did it in 1 hour!
  • Daniel30
27 Jan 2016 12:41 #161299 by Daniel30
Replied by Daniel30 on topic Jimny radio replacement
Mulberry wrote: How easy is it to fit a replacement aftermarket radio/nav/cd player into my 2005/2006 Jimny
Use the how to guide as mentioned but don't put the yellow clips back in until you are happy with how it fits it's easier to pull off again, I had to adjust my Sony one a couple of time using the different mounting holes, then put back the yellow clips :)
Time to create page: 1.364 seconds
