what reduction will i have?
  • jimnytsv
11 Nov 2015 20:21 - 11 Nov 2015 20:22 #156032 by jimnytsv
what reduction will i have? was created by jimnytsv
Hi all ive got a 2005 with the vvt push button type transfer case. im also running 30in tyres. Ive got a transfer case here out of the early model jimny(stick shift type) that has had the reduction gears changed. So ive spun the input shaft and i make it out to be about 1.7:1 in high and 2.7:1 in low. Can someone please help crunching these numbers to see what sort of reduction im going to have? I dont want to fit it if its not going to suitable. I do want reduction but how much this ratio is i do not know. Rear axle ratio i believe is 4.3:1. Also will the front and rear diff centres out of a seirra fit my jimny?? Would i have to change axles ? The front and rear housing has 8 bolts if thats any help .
Last edit: 11 Nov 2015 20:22 by jimnytsv. Reason: wrong info
  • TomDK
11 Nov 2015 21:46 #156044 by TomDK
Replied by TomDK on topic what reduction will i have?
jimnytsv wrote: Hi all ive got a 2005 with the vvt push button type transfer case. im also running 30in tyres. Ive got a transfer case here out of the early model jimny(stick shift type) that has had the reduction gears changed. So ive spun the input shaft and i make it out to be about 1.7:1 in high and 2.7:1 in low. Can someone please help crunching these numbers to see what sort of reduction im going to have? I dont want to fit it if its not going to suitable. I do want reduction but how much this ratio is i do not know. Rear axle ratio i believe is 4.3:1. Also will the front and rear diff centres out of a seirra fit my jimny?? Would i have to change axles ? The front and rear housing has 8 bolts if thats any help .
The most common gear reduction for a standard Jimny transferbox is a 25% reduction, so that's probably what you have. Also makes good sense as the standard low range is roughly 2.2:1
  • jimnytsv
12 Nov 2015 04:14 #156057 by jimnytsv
Replied by jimnytsv on topic what reduction will i have?
So do u think it might be to much reduction in high and not enough in lo??
  • TomDK
12 Nov 2015 12:20 #156089 by TomDK
jimnytsv wrote: So do u think it might be to much reduction in high and not enough in lo??
I'm not sure exactly what your problem is in the first place.. ??
The 25% reduction for the Jimny transferbox only relates to the low range. High range is not affected by this.
