Ignition/Starter Motor Problem?
- Jim Jimny 95
01 Nov 2015 19:25 #155100
by Jim Jimny 95
Ignition/Starter Motor Problem? was created by Jim Jimny 95
I recently had a new clutch fitted on my car and ever since it was done ive had the odd starting problem now and then. the majority of the time my car will start up fine with no problems whatsoever and then sometimes after a hour drive or so and the engine has been off i turn the ignition on and im not getting anything except from a buzzing sound and then after about a few mins the car will suddenly start up, any clue what this may be? any help would be much appreciated
01 Nov 2015 20:11 #155106
by Rhinoman
Replied by Rhinoman on topic Ignition/Starter Motor Problem?
It sounds like it could be a problem with the earth strap from the engine.
- rayz_x
02 Nov 2015 12:47 #155158
by rayz_x
Replied by rayz_x on topic Ignition/Starter Motor Problem?
Similar problem to mine. In brief the garage think it is Crank sensor, others disagree.
www.bigjimny.com/index.php/forum?view=topic&catid=7&id=58875
Ray
Ray
- Jim Jimny 95
11 Nov 2015 19:28 #156013
by Jim Jimny 95
Replied by Jim Jimny 95 on topic Ignition/Starter Motor Problem?
bit of an update, last week i used some sandpaper and gave the terminals a clean aswell as sanding abit of the paint away on the body of the car where the battery ground is located. I also checked the fuses in the engine bay and noticed the copper looked corroded, so i may yet change them at some point, but atm i havent used the car as much as i usually do but so far ive had no problems, i will keep you up to date if it comes back again
Time to create page: 0.157 seconds
