Interchangeability !!
- wombat
27 Oct 2015 14:36 #154577
by wombat
Replied by wombat on topic Interchangeability !!
If you want a hand just ask.
Ian
Ian
27 Oct 2015 14:58 #154579
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Interchangeability !!
If your jimny was an earlier g13b with the metal box ecu instead of the plastic one there are less common parts. I know yours (Chris) is the later. Handy having both models though so you can compare for sure before going ahead
Grey pick up Jimny
The following user(s) said Thank You: gusthegorilla
27 Oct 2015 19:50 #154627
by kirkynut
Replied by kirkynut on topic Interchangeability !!
I removed the loom from a Mk1 Nova Gte and adapted it to a Mk2 dash when I re shelled it into a Mk2 shell. I used masking tape on all wires as a label describing what it came off so laying it back in the car , routing it and re connecting it was easy.
I had to splice some bits together due to the plugs changing over the years but it wasn't tricky.
I've since seen Edd China use the same idea.
That's my top tip to making a loom swap easy.
The Jimny will be easier as nothing much changed on the switch gear or dials so you won't have that issue.
I would swap the whole loom to make it simple and work first time, even if it might seem a little more work. If you are a little unsure of the job you know that you have just moved the loom from one shell to another, so there's nothing to work out.
I hope you can get in small spaces at funny angles as some things like dash screws are often awkward to get at!
- Steveolkinevel
27 Oct 2015 20:34 #154635
by Steveolkinevel
Replied by Steveolkinevel on topic Interchangeability !!
I wouldn't bother with the m13 engine I hate mine, can't wait to get shot of it, my mates all run the g13's and they all run rings round mine and they have bigger tyres too
- gusthegorilla
28 Oct 2015 21:16 #154746
by gusthegorilla
Replied by gusthegorilla on topic Interchangeability !!
Well I'm stunned by the response guys... Kirkynut sowed the seed and then somehow I'm looking at a total transplant!!!!!
Hadn't considered that one at all, especially as there's nothing at all wrong with my single cam motor. Was simply a case of what to keep and what to sell....
Now I can spend the winter weekends carefully removing and labelling wiring looms, stripping and refurbishing a variety of other interchangeable bits, etc, etc...oh what joy...thanks a bunch Rob...Mate!!!!!
Thanks also to Ian the Wombat for your very kind offer of help....what you doing in the spring my friend!??
Oh s**t....where do I start???
Gus
Gus
28 Oct 2015 21:33 #154747
Replied by Daniel30 on topic Interchangeability !!
Who's going to be a busy boy then? :woohoo:
Time to create page: 1.407 seconds
