Single Jimnybits Front Recovery Point
I have bought a set of jimnybits front and rear recovery points and they look fantastic. Unfortunately I had an accident a couple of months ago and the passenger side chassis rail on the left side is bent. Not dramatically, but enough that the recovery point for that side won't fit, and I haven't been able to straighten it. I was just wondering if a single front recovery point on the driver's side would be sufficient for recovery? Is a single point strong enough?
Thank you very much
- Thank you received: 1888
- TomDK
furo wrote: Hello all,
Thank you very much
One recovery point is more than suitable for any situation. but requires that it's welded properly to the chassis. Meaning you need to weld it to the actual chassis, not the thin sub-rails that the front bumper is mounted to. If in doubt what I mean, take a look. It's pretty clear to see where the welds are.
Of course it's better with 2 recovery points like if one is stuck in the mud or such. For only 1 is needed for recovery.
