Anti roll bar removal
- Chris d
06 Aug 2015 19:05 #149234
by Chris d
Anti roll bar removal was created by Chris d
B)hi all can I remove my droplinks and anti roll bar if so do I need to add any bits spring retainers etc cheers
06 Aug 2015 19:08 #149236
The debate is lengthy about if to remove completely or not. I took mine right off and saw no real problems but restored it for the MoT.
Replied by helijohn on topic Anti roll bar removal
Chris d wrote: B)hi all can I remove my droplinks and anti roll bar if so do I need to add any bits spring retainers etc cheers
- Grego
06 Aug 2015 20:21 #149244
by Grego
Replied by Grego on topic Anti roll bar removal
No problem to remove arb and droplinks, I drilled four 30ish mm holes in the valance so I can remove or replace in 5 mins or so.
U cant see the holes unless you are underneath.
- Thank you received: 923
06 Aug 2015 20:48 #149246
Replied by X8GGY on topic Anti roll bar removal
OR... the best of both worlds -
Anti-Roll-Bar Disconnect from JimnyBits
Anti-roll-bar on on the road, off off the road
- Chris d
06 Aug 2015 21:06 #149253
by Chris d
Replied by Chris d on topic Anti roll bar removal
Grego can you post a photo tomoz so I can see your mod jimnybits disconnect not bad either but if I can mod for most and it works cheers guys P's silverdale September pps best backbox mods
- Grego
06 Aug 2015 21:06 #149254
by Grego
+1
Excellent bit of kit, bought and fitted one last month but a bit more expensive than just taking it off
Jimny-Dave wrote: OR... the best of both worlds -
+1
Time to create page: 2.776 seconds
