Advice On Engine Codes And Misfire
  • Olucas91
25 May 2015 10:07 #144775 by Olucas91
Advice On Engine Codes And Misfire was created by Olucas91
Was driving along yesterday and had a loss of power and engine started running rough. EML came on so plugged it in this morning and these codes came up;
P0135 02 sensor heater circuit malfunction Bank 1 Sensor 1
P0304 Cylinder 4 Misfire Detected
Is the first one the Lambda sensor on the manifold and has this caused the misfire in cylinder 4?
Thanks Ollie
25 May 2015 12:11 #144779 by Johnniehec
Hi no I've had an O2 heater circuit code for over two years with no associated problems. You've probably got a coil pack or plug problem. If the plugs were changed recently it' probably cool pack problem.
25 May 2015 17:27 - 25 May 2015 17:29 #144793 by Rhinoman
The O2 heater code will result in the ECU running in failsafe mode, you should fix that first and then move onto the misfire code if that comes back up again.
B1S1 is the first sensor, before the cat.
Last edit: 25 May 2015 17:29 by Rhinoman.
The following user(s) said Thank You: Olucas91
  • Olucas91
27 May 2015 17:13 #144898 by Olucas91
Replied by Olucas91 on topic Advice On Engine Codes And Misfire
All sorted changed the coil pack from 4 to 2 and registered a misfire on 2 so put a new one in today and has sorted it.
Time to create page: 0.250 seconds
