Metal valve dust caps
  • Yevad
26 Apr 2015 09:51 #143187 by Yevad
Metal valve dust caps was created by Yevad
I was looking for some nice chunky valve dust caps for my Jimny, as I'm off-road almost daily, and look what I found!
www.amazon.co.uk/Suzuki-Black-Metal-Chro...QM8/ref=pd_cp_auto_1
  • leswilluk
26 Apr 2015 10:11 #143188 by leswilluk
Replied by leswilluk on topic Metal valve dust caps
If you use metal caps as I do put a smear of grease on the threads if they corrode on you are in trouble
  • Yevad
26 Apr 2015 14:27 - 26 Apr 2015 14:28 #143194 by Yevad
Replied by Yevad on topic Metal valve dust caps
Yuppers. I use anti-seize lubricant. Bi-metallic corrosion is almost like welding sometimes! I believe these are chromed brass and the valve shanks are brass, so it should all be OK, but better safe than sorry ;)
Last edit: 26 Apr 2015 14:28 by Yevad.
  • Grego
26 Apr 2015 21:53 #143222 by Grego
Replied by Grego on topic Metal valve dust caps
leswilluk wrote: If you use metal caps as I do put a smear of grease on the threads if they corrode on you are in trouble
I learnt the hard way with ally caps :pinch:
  • gus2000
27 Apr 2015 18:13 #143259 by gus2000
Replied by gus2000 on topic Metal valve dust caps
Hello, you must be careful with the caps weight greater than the original
When the wheel turns, the centrifugal force expels tire inflation valve out, stopping return to the rest position.
This process results in the cyclic fatigue in the tire inflation valve can produce losses in the seal around the rim.
Gustavo
  • helijohn
27 Apr 2015 19:21 #143266 by helijohn
Replied by helijohn on topic Metal valve dust caps
Yevad wrote: I was looking for some nice chunky valve dust caps for my Jimny, as I'm off-road almost daily, and look what I found!
Had mine nicked by some kids..............chased 'em and got them back. :angry:
Time to create page: 0.196 seconds
