coolant temp sensor on 05 Jim
- virginian
18 Mar 2015 20:32 #140890
by virginian
coolant temp sensor on 05 Jim was created by virginian
Hi all, .. engine management indicator on dash telling me the coolant temp sensor is faulty,...got a pattern one for £12 cos Suzi main dealer quoted £55,....pattern one looks the same, but sends the dash gauge haywire, what do you suggest, try another pattern supplier or go OE ?
18 Mar 2015 20:41 #140894
by Rhinoman
Replied by Rhinoman on topic coolant temp sensor on 05 Jim
Have you checked the wiring? do the pins look clean? if that all checks out OK then I'd go for an OE sensor - if its not right it will throw the fuelling out but maybe not enough to trip a code.
- virginian
18 Mar 2015 21:08 #140902
by virginian
Replied by virginian on topic coolant temp sensor on 05 Jim
Ran the engine from cold on a Bosch diagnostic, and when the engine reached operating temp. the readout fell off to flatline and replace sensor showed. Either the replacement pattern sensor is the wrong one, or its dud. Put the original back in and original readout was repeated. £55 or Ebay?
19 Mar 2015 13:21 #140927
by Rhinoman
Does the replacement sensor show the correct temperature?
- virginian
19 Mar 2015 20:15 #140958
by virginian
No it sends the needle skywards
- teddy
07 Oct 2019 16:45 #214427
by teddy
Replied by teddy on topic coolant temp sensor on 05 Jim
id n
be interested to know if you got this problem sorted as i have the same happening .. my guage goes straight up after about 3 minutes but its not overheating ...ted
Time to create page: 0.156 seconds
