location of remote central locking module
  • Daniel30
09 Mar 2015 13:12 #140216 by Daniel30
Replied by Daniel30 on topic location of remote central locking module
Well done and good luck with the indicators
  • helijohn
09 Mar 2015 16:53 #140231 by helijohn
Replied by helijohn on topic location of remote central locking module
m6rk wrote: yep thanks people.. found it it finally..
Where was it precisely?? :unsure:
  • m6rk
09 Mar 2015 19:11 #140249 by m6rk
black box, tucked in line with the ashtray bolted to a metal upright. Pain in the arse to get to. I removed the the glovebox and ashtray.. turned out I needn't of bothered in the end!
Went for the simple option
Tapped the fusebox for live and ground
Wired two wires to the actuator which just pops the lock up and down
Tapped into the hazard switch for the indicators. Needed to use a relay to use the positive feed from the new
remote central locking unit and change it into a negative feed to make the indicators flash
Et voila..
I went with this method as I already had remote central locking but wasn't prepared to try and get a new remote and get it coded from suzuki
If I have time I want to connect it into the interior light so it comes on and fades when i arm/disarm the alarm..
Time to create page: 0.227 seconds
