Master cylinder repaire kit?
  • Mart3971
06 Mar 2015 07:03 #139985 by Mart3971
Master cylinder repaire kit? was created by Mart3971
Think my master cylinder is the cause of my brake pressure being poor. Have to press the pedal almost to the bottom before I stop. Anyone fitted a repair kit? I have a non abs model.
06 Mar 2015 08:15 #139986 by j999pre
Have you bled it at the compensater above the rear axle?
Grey pick up Jimny
  • Mart3971
06 Mar 2015 13:45 #139993 by Mart3971
Replied by Mart3971 on topic Master cylinder repaire kit?
No didn't relies there was a bleed nipple there.
06 Mar 2015 16:36 #140002 by j999pre
I had similar issues once and there was air there. Worth a try. Give the nipple a good soak with wd or similar first.
Grey pick up Jimny
  • miktt100
06 Mar 2015 17:45 #140007 by miktt100
Replied by miktt100 on topic Master cylinder repaire kit?
Second that !, I had similar problems and fitted repair kits on both front calipers , and the rear compensator was the prob :-(
06 Mar 2015 17:56 #140008 by facade
Replied by facade on topic Master cylinder repaire kit?
The Jimny has dual circuit brakes. If one circuit has run out of fluid/is full of air the pedal goes down a long way before the other circuit works.
The nipple on the compensator bleeds the front brakes.
Excessive travel at the rear brake shoes will also cause a low pedal, possibly because the magic adjusters aren't working if the cables are too tight.
A failed front wheelbearing will give a pedal that goes to the floor first time you brake, then pumps up to the top with repeated application when stopped, as the wobbly disc forces the pads apart when you drive.
Time to create page: 1.519 seconds
