Waffle Board Mounting
  • Dyl
11 Dec 2014 17:29 #132100 by Dyl
Waffle Board Mounting was created by Dyl
I have a pair of waffle boards I purchased before I got my winch.
As I'm sure you are all aware, they don't really fit in the back of the Jimny without annoyingly hanging over the front seats!.
I'm considering mounting them to roof bars so I have them with me at all times so am asking how you think I'm best achieving this.
I guess I could just get a couple of straps to hold them in place, but I think maybe something like bolts will be a better option.
Would you suggest, for example drilling the roof bars and running a long bolt through it with washer, going up through the waffle boards then some type of large washer with a nut on top? This is not my field of expertise ;) so forgive me if this sounds naive! If this is the way to go, any recommendations on the size of bolts and nots I would need such as M10, M12 etc?
Alternatively, do people think it's just not worth carrying them, as I must admit, I never see anyone else with them strapped to Jimny's :)
  • Ste001
11 Dec 2014 17:35 #132101 by Ste001
Replied by Ste001 on topic Re:Waffle Board Mounting
Roof bars drilled m8 should be more than enough then wing nuts for easy access ?
Sent from my Fingers using the Tinternet
11 Dec 2014 17:55 #132102 by jackonlyjack
Then get a cheap cycle lock
To make sure you still have them
:dry:
  • supergaz
11 Dec 2014 18:07 #132103 by supergaz
Replied by supergaz on topic Re:Waffle Board Mounting
Just use a roof rack and cheap ladder clamps.
11 Dec 2014 18:29 #132104 by Busta
Replied by Busta on topic Waffle Board Mounting
What about attaching them to the spare wheel? That way you avoid having a roof rack to catch on stuff when laning.
11 Dec 2014 19:09 #132108 by X8GGY
Replied by X8GGY on topic Waffle Board Mounting
On the roof (or outside anyway) is best, as once you've used them to rescue yourself from a quagmire of mud you won't want them inside then? ;)
I'm going to mount mine on my roofrack/treesliders as they'll then protect the hardtop section a bit too!
Dave
Time to create page: 0.170 seconds
