Alternator plug: help needed now!
06 Dec 2014 10:52 #131678 by facade
I can't get it off!
I can't see it properly, so what part of the brittle frozen plastic do I squeeze?
The shortest sides (90 degrees to where wire goes in)
The longest sides?
I need it off now, and all that is holding it in is the plug.
I can't get any tools to it working down the little hole between the radiator and the engine.
06 Dec 2014 11:13 #131680 by facade
Crisis over, I just chiselled it off with the screwdriver :ohmy:
No idea what held it on, hope it goes back in the new one... :blink:
06 Dec 2014 11:18 #131681 by j999pre
Short side squeeze
Grey pick up Jimny
06 Dec 2014 11:26 #131682 by facade
Cheers ;)
I squeezed both ways as hard as I could with numb fingers, but the plastic is rock hard in the cold, and it made no difference.
Stuck now until Tuesday until the re conditioners open again and I'm not working late.....
Whats the betting that there will be 8" of snow on Sunday and I have to use The Other Car Monday Tuesday?
06 Dec 2014 12:54 #131683 by j999pre
I have alternators if you get stuck
Grey pick up Jimny
06 Dec 2014 13:30 #131685 by facade
Thanks, I'll bear it in mind.
I'll see how much an exchange one is Tuesday (and whether they are in stock).
Mine was seized solid this morning, when I got it off it turned backwards with some rubbing, now it is in the house it seems perfectly ok.
(no water has come out, so it can't be frozen, I expect it is a brush worn out and chewed into the slip rings, but when I took the lid off there were far too many screws to undo)
Cheap Denso rubbish, can't have done more than 140,000 miles :laugh:
Time to create page: 3.013 seconds
