engine swap to g16b queries
- suzukisam
06 Nov 2014 20:02 #128755
by suzukisam
engine swap to g16b queries was created by suzukisam
I have just got a g16b engine from a baleno but need to swap camshaft from my g13b now ive heard it wont rev as high if I do this ?
Is this true and does it affect it much or is it not really noticeable
Cheers sam
Cheers sam
06 Nov 2014 20:29 #128762
by j999pre
Grey pick up Jimny
Replied by j999pre on topic engine swap to g16b queries
If the Jimny cam and the baleno cam are the same diameter on the cam pick up end you could swap the 2 lobe ring for the 11 lobe. The cam would then rev as normal. You would have to make sure you got in exactly the same place by marking the 2 cams up first. A little bearing puller should pull it off ok.
Grey pick up Jimny
- suzukisam
06 Nov 2014 20:49 #128764
by suzukisam
Cheers james all sounds like scary work lol if I decided to run the jimny cam is it a massive difference or not really noticeable ?
Replied by suzukisam on topic engine swap to g16b queries
j999pre wrote: If the Jimny cam and the baleno cam are the same diameter on the cam pick up end you could swap the 2 lobe ring for the 11 lobe. The cam would then rev as normal. You would have to make sure you got in exactly the same place by marking the 2 cams up first. A little bearing puller should pull it off ok.
07 Nov 2014 08:26 #128792
by j999pre
Grey pick up Jimny
Ask vitmad I think he has used the Jimny cam in a g16.
Grey pick up Jimny
- vitara_mad
09 Nov 2014 09:47 #128986
by vitara_mad
Replied by vitara_mad on topic engine swap to g16b queries
yes ive used jimny cam in baleno engine & found it to be fine
- TomDK
09 Nov 2014 09:56 #128987
by TomDK
Replied by TomDK on topic engine swap to g16b queries
But why not just change the pick up cam. It is very easy to do, and there are already marks on the pick up and the cam shaft it self. I did it when I changed camshafts and head.
Time to create page: 0.158 seconds
