Putting vit crown/pinion gears in Jimny diff
- tim_jimny53
23 Sep 2014 17:13 #124877
by tim_jimny53
Putting vit crown/pinion gears in Jimny diff was created by tim_jimny53
Hi all just wondering if any1 tried doing this to lower the ratio's instead of a rock lobster , any info's much appreciate cheers
23 Sep 2014 18:10 #124881
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Putting vit crown/pinion gears in Jimny diff
I have a pair of diffs from a 2006 jimny for sale these are 4.3 instead of 3.9 so should give a 10% reduction
Not sure on the vit swap but someone on here will know
Grey pick up Jimny
- irishguy123
23 Sep 2014 19:22 #124886
by irishguy123
Replied by irishguy123 on topic Putting vit crown/pinion gears in Jimny diff
Just out of interest what sort of money would you be looking for? I wouldn't mind doing this swap at some stage in the future... Do the newer diffs fit without modification?
Cheers
Cheers
23 Sep 2014 19:43 #124889
by j999pre
Grey pick up Jimny
I think the crown wheel is slightly bigger so you need to make a slight adjustment to the casing to get them in the front. The skit needs enlarging slightly. The shafts are all the same so no problems there.
Grey pick up Jimny
The following user(s) said Thank You: tim_jimny53
- tim_jimny53
23 Sep 2014 20:32 #124901
by tim_jimny53
Replied by tim_jimny53 on topic Putting vit crown/pinion gears in Jimny diff
Ok thanks for the advise , cheers for the offer on em 06 diffs to but think need bit more reduction getting a lock right fitted so thinking bout getting ring/pinion done at same time also running 31 10.50 15 special tracks remember seeing something bout Jimny auto diffs to , they lower ratio aswell?
24 Sep 2014 06:12 #124915
by j999pre
Grey pick up Jimny
Auto diffs are 4.1 so not as much reduction as vvt diffs
Grey pick up Jimny
Time to create page: 0.147 seconds
