How to fit corrected rad arms
25 Sep 2014 04:03 #125026 by kirkynut
TomDK wrote:
kirkynut wrote: Tom you're making hard work of it. Leave the wheels on the car and the car on the ground but chock the wheels on the axle you're working on so it doesn't roll off on its own.
Undo one arm and change it to start with as the other being attached stops it rolling away too.
Fit the first one at the axle end only.
Completely remove the 2nd arm and fit the new one at the axle end only.
Then fit the chassis end of both and you won't be fighting each side.
I hope that's clearer.
By leaving it on its wheels you allow the axle to turn with the castor correction.
Just be sure to chock the wheels well.
You can use a jack to hold the weight of the chassis end of the arm if needs be.
Perhaps I was a bit unclear. I mean Jack the car up, but stands under the chassis rails, one on each side just behind the radius arm mounts. Then it's easy to remove the front wheels with much better access to work on the radius arms, suspension and so on. And the car won't roll a bit ;)
But I want the wheels on the ground for a reason. It's so you can rotate the axle easily and let's face it, there's plenty of room under a Jimny.
Maybe jack it up and remove the wheels to loosen the bolts if they will but otherwise leave it on its wheels.
  • TomDK
25 Sep 2014 07:04 #125035 by TomDK
Replied by TomDK on topic How to fit corrected rad arms
I see your point Kirky.
We have our own way of doing things :) I just like to remove the wheels to have the room. And with the axle sitting on the jack, it's very easy to rotate, as it's pretty light. Not like a Patrol axle or something :D
  • tim_jimny53
25 Sep 2014 14:39 #125067 by tim_jimny53
Replied by tim_jimny53 on topic How to fit corrected rad arms
Haha no worries guys getting there almost completed the rears will probably do the fronts over tet weekend thanks for the advise
  • tim_jimny53
25 Sep 2014 15:27 #125073 by tim_jimny53
Rears complete , will put sum pics up soon of my Jimny it has grown quite a bit over the last month , so the fronts going to be any easier ? :laugh:
  • TomDK
28 Sep 2014 20:31 #125324 by TomDK
So did you get the front ones installed as well or do you need a few pics? :)
  • tim_jimny53
28 Sep 2014 20:38 #125328 by tim_jimny53
Nah I didn't have ago this weekend been quite busy , can see that I'm goin to have to move the shocks out the way , if you don't mind mate think it may help :)
Time to create page: 1.871 seconds
