tyre preasure ?
  • handybutton
21 Aug 2014 23:48 #122513 by handybutton
tyre preasure ? was created by handybutton
Hi all need some help! What are people running their tyre preasures at? Have read so many different preasures dont know which one to belive. I am running 215/80/15 on my jimny. I know tyre preasures dont go up just cause you get bigger tyres. I am running them at 27 psi at mo. What are peoples thoughts on this?
Thanks
  • hunter1084
22 Aug 2014 00:42 #122515 by hunter1084
Replied by hunter1084 on topic tyre preasure ?
Standard pressure for jimnys on stock 205/70 r15 tyres is 23psi front and 26 psi rear if that helps. Your tyres are bigger but you can always try it out and see how it handels
22 Aug 2014 07:28 #122520 by robs5230
Replied by robs5230 on topic tyre preasure ?
found standard pressures 23 and 26 best all round. higer pressures mean less rolling resistance but will wear the centre of the treads.
standard jimny - for now
The following user(s) said Thank You: handybutton
  • Brave
22 Aug 2014 11:32 #122532 by Brave
Replied by Brave on topic tyre preasure ?
I'm running 235/75/15 with 24 front and 22 back. This is still a little high but good on the road. To calculate the correct tire pressure the best way is
1 trial end error find what you like best.
2 chalk the tire and make sure the contact area is correct
3 use tire pressure charts. Find the standard tire in the chart and cross reference the tire pressure to load rating, then use this info to cross reference your new tire size.
  • Shep
22 Aug 2014 11:37 #122534 by Shep
Replied by Shep on topic tyre preasure ?
I have 245/75/16 tyres and run 18psi front and rear with 6-8psi when off road
  • Docmartin4x4
24 Aug 2014 23:16 #122685 by Docmartin4x4
Replied by Docmartin4x4 on topic tyre preasure ?
Wow, that is low! I do tend to run low off road but 15psi as i get pissed off of pulling stones and shit out of the tyre bead afterwards!
Mart
Time to create page: 0.287 seconds
