Exhaust emission warning light
  • chalks
28 Jul 2014 19:35 - 28 Jul 2014 19:38 #120888 by chalks
Exhaust emission warning light was created by chalks
My ' emissions' warning light has come on and so far I have ignored it. The book says it can harm the system to ignore it. is this true? What triggers it and how can it be fixed. I have a 2002, cheapy runaround so nothing expensive! Any advice
Last edit: 28 Jul 2014 19:38 by chalks. Reason: Error
28 Jul 2014 19:44 #120889 by j999pre
Probably the lambda sensor in the exhaust manifold. 1 minute garage job to read the codes to make sure or buyl a cheapo eBay reader and check yourself
Grey pick up Jimny
The following user(s) said Thank You: chalks
  • vitara_mad
28 Jul 2014 20:06 #120890 by vitara_mad
Replied by vitara_mad on topic Exhaust emission warning light
no code reader needed
www.rhinopower.org/diag/cel.html
28 Jul 2014 20:16 #120891 by j999pre
True, I just find it quicker and easier for repeated use.
Also you can use it on other cars if you have access.
Grey pick up Jimny
29 Jul 2014 12:14 #120932 by Rhinoman
If its EOBD then it won't have the CEL option. You should pick up a cheap scan tool, they aren't much more expensive than a code reader and give far more information. Most of the failsafe modes will cause it to run rich will eventually damage the cat.
Time to create page: 0.745 seconds
