Rear bumper removal and fitting Suzuki towbar
  • Johnbrom
09 Jul 2014 20:00 #119613 by Johnbrom
Hi all
I have just bought a Suzuki towbar and am looking for advice and tips about how to remove
the rear bumper and general fitting of the towbar.
Any and all advice appreciated
thanks
JohnB
09 Jul 2014 20:03 - 09 Jul 2014 20:05 #119615 by dirtydogz
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 09 Jul 2014 20:05 by dirtydogz.
  • Johnbrom
09 Jul 2014 20:20 #119621 by Johnbrom
Replied by Johnbrom on topic Rear bumper removal and fitting Suzuki towbar
Thanks for those quick replies. I have read them and think perhaps I should have gone for the Towtrust bar and not a genuine Suzuki one.
Are there any guides for the rear bumper removal, I have searched but with no luck
thanks
  • markyp2000
10 Jul 2014 17:06 #119698 by markyp2000
Replied by markyp2000 on topic Rear bumper removal and fitting Suzuki towbar
Its easy remove both upper body lights theres a bolt behind them then under the wheel arch there are 2 bolts on each side under neath the pasengers rear bumper there is a wireing loom that goes through the body pull that out and unplug it then there is 2 bolts under neath the bumper then 3 bolts inside the rear door shut then it will come off hope this helps
  • Bits4Vits
10 Jul 2014 17:14 #119703 by Bits4Vits
Replied by Bits4Vits on topic Rear bumper removal and fitting Suzuki towbar
markyp2000 wrote: Its easy remove both upper body lights theres a bolt behind them then under the wheel arch there are 2 bolts on each side under neath the pasengers rear bumper there is a wireing loom that goes through the body pull that out and unplug it then there is 2 bolts under neath the bumper then 3 bolts inside the rear door shut then it will come off hope this helps
That helps me too! Thanks Mark ;)
Have an ORA bumper coming...
  • Johnbrom
10 Jul 2014 18:17 #119712 by Johnbrom
Thanks Mark thats superb, thanks for the heads up on where to look for the bolts.
I have just seen that the make of the towbar is AL KO. Its very substantial for such a small car.
Hope to fit on the weekend. :cheer: :cheer: :cheer:
Time to create page: 0.249 seconds
