Airbag warning light
  • nick40
24 May 2014 15:39 #116186 by nick40
Airbag warning light was created by nick40
hi Folks
I am brand new to the Jimny world having owned mine for 8 weeks now and I am pleased to have found a jimny forum.
She is a 2002 Spanish Built G13bb engined soft top that has done 30,000 miles, I have done a few jobs on her now, new fluids in everywhere fluids go, new lambda sensor which sorted out engine light and new cambelt.
I am looking for a bit of input, I have a airbag warning light on constantly and I have diagnosed it by earthing the reader socket and got a code 21, drivers airbag resistance high. so a couple of questions?
1. If I replaced the airbag and clockspring how would I then reset the light without a suzuki tool and is this likely to solve the problem?
2. Am I better of letting someone who knows airbag systems sorting it out and can anyone recommend some one, I am in Northamptonshire but don't mind travelling a reasonable distance.
3. anyone got anything else to add?
Thanks everyone in anticipation
Nick
24 May 2014 16:04 #116188 by j999pre
Replied by j999pre on topic Airbag warning light
The air bag is quite easy swap and the system checks itself when you turn the ignition on so it should reset once you fix the fault. Make sure the battery is disconnected for a while before you work on it.
I have a full airbag kit from a g13b if you are looking for one, both bags and the controller
Grey pick up Jimny
  • markyp2000
24 May 2014 16:31 #116189 by markyp2000
Replied by markyp2000 on topic Airbag warning light
Does the horn still work id start by disconecting the battery then unplug all the wires for the drivers air bag and plug them all bach together reconnect the battery and see if the light goes out
  • Hobbs
24 May 2014 22:38 #116216 by Hobbs
Replied by Hobbs on topic Re:Airbag warning light
My horns stopped workin and airbag light came on ! Any ideas ?
  • markyp2000
25 May 2014 09:25 #116232 by markyp2000
Replied by markyp2000 on topic Re:Airbag warning light
Hobbs wrote: My horns stopped workin and airbag light came on ! Any ideas ?
it will be the ring behind the steering wheel
  • Hobbs
25 May 2014 19:26 #116274 by Hobbs
Which ring is this ? Ill get it off tonight and have a look
Time to create page: 3.264 seconds
