Manual Hubs
  • Carrow
12 May 2014 22:11 #115013 by Carrow
Manual Hubs was created by Carrow
Hi,
Just fitted Manual Hubs, on my 2008 Jimny. I have blocked off the air tubes at each hub, 4x4 light works a treat and transfer box selects 4x4 as it should. What I want to know is, can I keep the hubs locked in 4x4 on road (with 4x4 dash switch not selected), and use the electronic 4x4 dash. selector switch when I go off road. or will this damage something. Just so I don't need to stop and get out and lock hubs, when I know I will be going off road. Cheers.
  • jimnylee
12 May 2014 22:32 #115015 by jimnylee
Replied by jimnylee on topic Manual Hubs
Hi Carrow. I have meant to ask the same thing, I had manual hubs on my 2001 when I bought it and also unsure :S :unsure:
  • Yellostreak
12 May 2014 22:35 #115017 by Yellostreak
Replied by Yellostreak on topic Manual Hubs
don't see why not... the original SJs and Vitaras where fixed hubs and used the transfer box to disconnect.. same with old series Landrovers and many other Jap part time 4wd motors..
the original reason for fitting free-wheel hubs was to save fuel and wear and tear on the front drivetrain.
mine is manual and its a bit more agricultural on the occasions I have the hubs locked up but in 2wd.
  • helijohn
12 May 2014 22:52 #115024 by helijohn
Replied by helijohn on topic Manual Hubs
I leave my front manual hubs engaged all the time so when I select four wheel drive I don't have to faff about engaging the hubs.
I did the same on my SJ too as has been suggested.
If I were going to scream down the motorway at 70mph for a few hours I would likely consider setting the hubs to freewheel first.
  • hunter1084
13 May 2014 04:33 #115035 by hunter1084
Replied by hunter1084 on topic Manual Hubs
My mate (has a 1994 hilux) told me a while ago that its fine to leave them in on short trips and safer to unlock them on long trips
13 May 2014 06:43 #115037 by kirkynut
Replied by kirkynut on topic Manual Hubs
I have fixed hubs that are therefore permanently locked. SJs & Vitaras used to only have manual hubs as an option. It was an option a lot of people had but standard fit were fixed hubs.
So yes, you can leave them locked when not in 4wd.
People will tell you it uses more fuel but I say poppy cock! You'd barely notice it if you were to notice it.
It will wear on the oil seal but if you change that regularly with your kingpin bearings it won't be SJ issue.
The following user(s) said Thank You: Carrow
Time to create page: 0.166 seconds
