engine oil flush good or bad
- jimnylee
10 Apr 2014 20:11 #111851
by jimnylee
engine oil flush good or bad was created by jimnylee
Hi folks I'm planning given the jimny it's first engine oil and filter change since I got it , it's got 72k on the clock, the engine oil is manky , I'm thinking about using an engine oil flush I have used them in previous cars I've had without any issues but now here conflicting stories some say it's bad some say it'd good? ,Does anyone else use engine flush on there jimny?
- steffan
10 Apr 2014 20:19 #111853
by steffan
Replied by steffan on topic engine oil flush good or bad
Personally I would as it thins the oil and helps clear the gunck out
- Bigjim91
10 Apr 2014 20:35 #111855
by Bigjim91
Replied by Bigjim91 on topic engine oil flush good or bad
If ya head gaskets gone then yer
- markyp2000
10 Apr 2014 21:15 #111859
by markyp2000
if your going to do it buy a good branded one
or drain it when its hot
Replied by markyp2000 on topic engine oil flush good or bad
Bigjim91 wrote: If ya head gaskets gone then yer
- jonathan
12 Apr 2014 17:29 #112001
by jonathan
Replied by jonathan on topic engine oil flush good or bad
it is good to put an engine flush through them every so often and cleans out the oil ways and frees the oil control rings
- auchenblae
- Elite Member
- Thank you received: 25
13 Apr 2014 17:12 #112090
by auchenblae
If the engine has had regular oil changes with high spec oils there is no need to use a flush as the inside of the engine will be spotless. I just changed the sump on our 52,000 mile, 07 car and it was as clean as a whistle inside.
If you cannot vouch for the previous owners oil change habits, it may make you feel better to use a flush but modern synthetics and the latest modern mineral oils will do the job just as well.
As for "jonathan" post can you please and advise how a stuck ring which will be blocked with carbon will release it's self from the ring grove with 5 minutes of a run of flushing oil that does not get into the carbon in the ring grove to dissolve it.
Or can you provide some logic here jonathan that I am missing.
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Replied by auchenblae on topic engine oil flush good or bad
jonathan wrote: it is good to put an engine flush through them every so often and cleans out the oil ways and frees the oil control rings
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Time to create page: 0.178 seconds
