Gearbox rebuild - £1400!!!
- GuardianAngel
18 Feb 2014 22:53 #105134
by GuardianAngel
Gearbox rebuild - £1400!!! was created by GuardianAngel
A friend of mine has a 2008 Jimny and recently a bearing in the gearbox (manual) failed and sprayed bits all around the inside of the box, trashing a lot of the gears.
He has just spent £1400 on getting it rebuilt which to me sounds like he has been ripped off. He insists that because it's a later version with the electronic TB, that the gearbox is different and therefore the cost is much higher. I really can't see why it would be so different to the earlier versions that a second hand box would not be far cheaper to buy and fit.
Maybe I am missing something here?
- bluejimny
18 Feb 2014 23:03 #105136
by bluejimny
Replied by bluejimny on topic Gearbox rebuild - £1400!!!
yes does seem expensive, depends if he's had replacement gears etc that would be main dealer only??
my question is... would an older gearbox eg 2003 model fit the newer vvt engine?
surly would be cheaper to then get a intermediate prop modified to suit? if this it the case?
- Bigjim91
18 Feb 2014 23:06 #105137
by Bigjim91
Replied by Bigjim91 on topic Gearbox rebuild - £1400!!!
:ohmy: I paid less then that for my Jim!
- GuardianAngel
18 Feb 2014 23:08 #105140
by GuardianAngel
Replied by GuardianAngel on topic Gearbox rebuild - £1400!!!
Apparently it was a 4x4 specialist here in Redhill, Surrey.
To make matters worse he drove it home and it kept popping out of gear, so it has got to go back and be stripped down again.
19 Feb 2014 07:47 #105149
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Gearbox rebuild - £1400!!!
Cam Suzuki do exchange boxes for the vvt for £850 ish
I think gearing is different on the earlier boxes. You would need the earlier prop to and then fabricate a gearbox mount as I believe its in a different place.
Grey pick up Jimny
The following user(s) said Thank You: GuardianAngel
19 Feb 2014 12:08 - 19 Feb 2014 13:33 #105175
by gilburton
Replied by gilburton on topic Gearbox rebuild - £1400!!!
If the box internals have been trashed then that probably includes the mainshaft and probably some gears??
An exchange box from Suzuki is app £2500!! If caught in time and it's just bearings/seals it'll be around £850.
These boxes are different from the earlier ones so it's not a bolt in swap.
Just do a search on here for "VVT gearbox" and you will find plenty of posts.
The VVT box is fragile and seems to have some issues.
I believe they have lubrication issues on the output bearing and it has been replaced with a sealed version??
As others have found out VVT boxes are rare.
The early VVT models suffered from a manufacturing fault on the gearbox-T/F box prop. which allowed oil to leak out the gearbox.
This was replaced under warranty but a few escaped(like mine) but was caught before too much oil was lost so a new propshaft/output seal cured it but at my cost at 33000 mls but well out of warranty.
The dealer just charged for the parts
Last edit: 19 Feb 2014 13:33 by gilburton.
Time to create page: 0.592 seconds
