What next....
  • Beano
25 Jan 2014 11:59 - 25 Jan 2014 12:02 #101948 by Beano
Replied by Beano on topic What next....
G13bb -
Front= APl GL5 1.35 litres 80W 90
Rear= APl GL5 1.5 litres 80W 90
M13AA -
Front = APl GL5 1.1 litres 80W 90
Rear = APl GL5 1.3 litres 80W 90
If I remember correctly....
*EDIT* - sorry, didn't say that this was the diff oils.... :laugh:
Last edit: 25 Jan 2014 12:02 by Beano.
  • idiotmobil
25 Jan 2014 12:11 #101950 by idiotmobil
Replied by idiotmobil on topic What next....
Do it before the lift or after the correction bushes go in as this will tilt tge axles giving a false amount of oil in diffs as filler bung will be lower less oil in diffs not good
25 Jan 2014 12:58 #101957 by robs5230
Replied by robs5230 on topic What next....
idiotmobil wrote: Do it before the lift or after the correction bushes go in as this will tilt tge axles giving a false amount of oil in diffs as filler bung will be lower less oil in diffs not good
+1 been there and done that :)
standard jimny - for now
25 Jan 2014 13:02 #101960 by robs5230
and before you get everything ready to change the diff oils visit your local main stealer and get a pair of new diff filler plugs. the old ones can be a real nightmare to undo. had to weld bolts to mine. it's a square 10mm recessed hole. a 3/8 ratchet head ( usually what most lads will try first ) will round the square hole. a good dose of heat may help. i bought the correct 10mm square tool and it bent
  • idiotmobil
25 Jan 2014 15:51 #101981 by idiotmobil
just make some square bits to weld in the holes and theen you can just undo with a spanner when ever they need doing 3/8 undone mine but ive got a 3/8 with the rounded end cut off so its more square works a lot better
  • craigy123
25 Jan 2014 17:05 #101990 by craigy123
Replied by craigy123 on topic What next....
Will this do the job?
