Radio and CD cutting out after a few minutes
- Raithrover
20 Jan 2014 20:51 #101342
by Raithrover
Radio and CD cutting out after a few minutes was created by Raithrover
Radio and CD player cuts out after 5/6 minutes and 2/3 minutes respectively. Will only come on again after car has been parked up for 10/15 minutes. Fascia is lit and clock works fine. Possibly something overheating ? 2007 Jimny
a) What may the problem be ?
b) Solution ?
b) Solution ?
- RichiesJimny
20 Jan 2014 20:59 #101344
by RichiesJimny
Replied by RichiesJimny on topic Radio and CD cutting out after a few minutes
Possibly the alternator over charging, put a volt meter across the battery and check the voltage it should be around 14.5 volts with the engine running at about 3000rpm.
- Raithrover
22 Jan 2014 22:41 #101641
by Raithrover
Replied by Raithrover on topic Radio and CD cutting out after a few minutes
Well, it isn't the alternator. Getting 14.84 through it.
23 Jan 2014 04:03 #101659
by kirkynut
Replied by kirkynut on topic Radio and CD cutting out after a few minutes
Sounds like the head unit is toast. I'd just get an aftermarket one which will sound better anyway.
